dave tuttle
60 points
Posted on - 11/21/2012
I have been wondering if I could share my laptop/PC internet connection with my Android phone via USB .
Please explain how to achieve this reverse tethering from PC to Android via USB.
How to connect the PC internet with Android via USB?
Dear Dave,
I hope you are doing  well. Regarding your query, here I am sharing a link with you, which will help you to connect to the internet via USB using the ANDROID OS, here is the link where you can get it.
It helps completely and has step-by-step guides.
Install your Android phone software in your computer. Plug the data cable with Android Phone and your PC.
After plugging your data cable with your computer and Android Phone look Android Internet connector box.
Please Select "Select Device" from the drop down box. Nest click the connect option.
After a few seconds the Android phone and PC shall connected internet service.
rbeemark
In order to connect PC internet to android via USB, first of all plugs your USB to your Android device and go to Reverse Tether and open it then choose connect via a USB option, after that open internet it will take a while it's just like a 3G connection, after a while you are connected to the internet it's done.
In order to disconnect internet simply unplug USB.
Hi Dave Tuttle,
Android mobile as a modem to access the internet from the PC group:
On to USB Debugging Mode. Follow the following command on USB Debugging Mode.
Home/App drawer>Settings>Applications>Development>USB Debugging (Select) [ select the Empty box with a check mark USB Debugging ]
Mobile network connection with, Follow the following command on the mobile net connection.
Home / App drawer> Settings> SIM Management> Data Connection> Select SIM.
Connect your device with your PC via the data cable.
On your USB tethering, On the following command.
Home/App drawer>Settings>Wireless and Networks>Tethering and Portable hotspot>USB tethering (Select) [Select the empty box with a check mark's use USB tethering]. Wait, (avg. 45 second ), Your PC is now ready to use the net. You are now able to use the net from your PC.
mohsinaece
