How to connect report builder 10g to database?
How to connect report builder 10 g to database? And I need some online eBooks or tutorial for any database commands and features. I want to study more about this, all related to my database project will do. I need your suggestions.
Thank you.
Answered By 10 points N/A #146432
It is very easy to connect report builder 10g to a database. Before you connect the report builder to the database make sure that there are no mistakes as you cannot change it after connecting to the database. Also check whether the database is working correctly and check the security measures of the database to protect your data.
It is very essential to check the security features before you load data to a database. Check the authenticity of the provider and obtain the usernames and passwords to access your data. Also set a password to your data so that only the users who know the password can open the data you loaded.
The following websites offer tutorials for the report builder and the database features:
1. Scribed – https://www.scribd.com/document/3960412/Basic-2-Oracle-Reports-10g-Tutorials
2. https://docs.oracle.com/cd/B14099_17/bi.1012/b14364.pdf – This is a PDF link, the PDF file contains the tutorial.
