How to connect Samsung TV to Wi-Fi network?
Asked By 15 points N/A Posted on -
Hi everyone! I’m trying to get the wireless network of my home to communicate with the Samsung TV which is just one or two months old. However, the connection gets failed every time. Please guide me on how to connect Samsung TV to Wi-Fi?
Answered By 10 points N/A #155997
To connect the Samsung LCD Television to your wireless network, you need the following:
ï‚· Wireless router ï‚· Internet connection
ï‚· Wireless adapter compatible with your TV
ï‚· Network Name
ï‚· Security Key To begin connecting, follow the steps below:
 Connect the Samsung’s wireless adapter to the USB port on the TV.
ï‚· Press the Menu button on remote, and then Select Setup > Network.
ï‚· Choose the Network Type as Wireless.
ï‚· Go to Network Setup, and then choose the name of your wireless network.
ï‚· Use the remote control keys to enter the encryption key of the router. Type the password, and then press Enter.
ï‚· Wait for some seconds for the TV to get connected to the Wi-Fi.
ï‚· Now, press Return.
ï‚· Select Network Test for the TV to check whether the network is working properly.
