How to connect the two networks
I have a home based studio, with a phone jack and modem or router box. The studio has a network based on a Netgear modem router dgn3500 (192.168.0.1) to a home network based on a Livebox (192,168 .1.1) how to connect the two networks so that the machines one can send files to each other and share resources and vice versa?
I think we have already kept them in the same Workgroup but even after that it’s not communicating with each other.
Thanks for the help.
Answered By 0 points N/A #154188
Hi Jonathon Head?
 I have read your problem. Follow the following process for solving your problem:
1. Change the computer name an of course the work group. all the computers must same Workgroup and type the name all capital. After change the name and Workgroup you must have rebooted the PC otherwise your system will not work.
2. After change this you will go to setup IP Address by clicking the network adapter and set the subnet mask all the LAN 255.255.255.0
3. If you want to share the Folder  system you will need to share the Folder by right mouse click on the desired folder and select properties then click share this folder.
4. After this if your network system does not work you may check your cable.
Thanks
