How to connect vba access 2010?
Hello techyv,
I would like to connect my visual basic 6 calculator system in Microsoft Access 2010 database.
I need a database that will hold all the possible data to be entered and save by the system user.
Can you give me a step by step process on how to connect it properly?
This is for my office database.
Expecting some help from you guys.
Thank you.
Answered By 0 points N/A #185889
To connect to VBA in access 2010,you need to use the code below:
Dim sSQL As String
Dim rs As ADODB.Recordset
Dim cn As ADODB.Connection
Set cn = New ADODB.Connection
cn.Open "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=S:MyFoldermyDB.accdb;Persist Security Info=False"
sSQL = "Select top 2 from Table1"
Set rs = New ADODB.Recordset
rs.Open sSQL, cn
ActiveWorkbook.Sheets("Control").Cells(6, 1).CopyFromRecordset rs
rs.Close
Set rs = Nothing
cn.Close
Set cn = Nothing
If there are any errors, use the following code in rs Run-time error '-2147217900 (80040e14)':  Automation error and you want to VBA for Access 2010 to SQL 2008 R2 just visit this link
Thanks, Max
