How to connect Windows 8 beta to magicJack?
I just bought a MagicJack and I cannot connect it to my HP laptop. Is there an updated driver released I can connect my HP laptop's Windows 8 beta to magicJack?
Thank you for your question.
MagicJack will have to release an update driver with proper support for windows 8. Windows 8 will release on October 2012. So most likely it will not be until Oct when windows 8 gets released to the world and only the final versions of windows 8, not the Preview Builds.
So you have to wait till then
Hi!
You might want to upgrade your copy of Windows 8 hence there is a big difference between a beta version and the full blown Windows 8. Devices connected to the beta version of Windows 8 will definitely experience compatibility issues as the updates for the drivers are not available. It’s more like in a “testing phase”.
However, I have done my research with regard to the compatibility of the device to Windows 8 and it shows:
Hope you find this information helpful.
Jim Krueger
