How To Connect To Work Computer From Home
Hi. I am currently working in an IT firm. I would like to learn how to connect to work computer from home. Please let me know the steps for the same. Thanks in advance.
Hi. To set up a remote access to your office, learn how to connect to work computer from home by setting up the office computer such that it accepts the remote desktop connections. Click on the Windows key from the keyboard and then select the properties option after right-clicking on the icon of “my computer”. Then, click on remote settings. For Windows 7, if you want to allow the connections from computers running Remote desktop only with network level authentication, then, click on this option appearing on the screen. Click on the computer name and then note down the full name of the computer.
You can connect to the office computer remotely by clicking on the Windows logo, then click on start option, then select all programs, click on accessories and then select the option named “remote desktop connection” after which a dialog box of remote desktop connection will appear in which you need to type the name of the computer. Then click on show options. After clicking on the Advanced tab, click on settings option.
Use the RD Gateway server settings by clicking on the option and then typing “rdg.ssc.wisc.edu” as the server name. Mark the option of use my RD Gateway credentials for the remote computer and select OK. You will then get connected to the office computer remotely and you can logout when you are done.
Hope we helped.
