I know that I can connect to my computer from my XBOX console using Windows Media Center but I don't know how. I'm running Windows 7 on my computer. I use a router for my home network, how do I set it up? Do I need a cable or can I use the wireless network to connect?
How to connect XBOX to my laptop using WMC
Hi Gabrielleriya,
I would be more than happy to assist you in connecting your Xbox console to your PC using Windows Media Centre. Just follow the simple steps below:
1. Press the Guide button on your Xbox controller.
2. Navigate to Settings, and select System Settings.
3. Choose Network Settings.
4. Choose the name of your wireless network, or choose Wired Network if you have a wired connection.
5. Choose Test Xbox Live Connection.
This should help you!
