How To Connecting To The Ink For Epson XP 400 Printer
Hi. I am not very comfortable with the computer-related hardware and software. I want to know the steps to connect to the ink for Epson XP 400 printer. Please reply ASAP. Thanks in advance.
Hi. The steps to replace the ink for Epson XP 400 printer require you first to make sure that no USB cable is connected to the PC. Next, the disc which came with the printer needs to be inserted in the CD-drive and then launched. Next, run the executable file of the setup and then install the software of the printer on the screen by clicking on the install option. Then, connect the printer to the PC by either selecting the wireless option or the USB option. Then, by the network chosen by you, the steps appearing on the screen for the installation need to be followed.
Hope we helped.
