How To Contact HP Help And Support Centre?
I tried solving the problem of HP Laptop not starting using your troubleshooting methods, but it did not work. So I need to contact HP Help and Support Centre. How do I contact them?
You can find information about contacting HP service centre online. Here, I have listed a few ways of how to contact HP Help and Support Centre:
1. Contact HP using product-specific toll-free number:Â http://www8.hp.com/in/en/contact-hp/phone-assist.html
2. I am even listing city-wise service centre number for some specific cities:
Ahmedabad – 07930304499
Chennai – 04430304499
Bengaluru – 08030304499
Delhi – 01130304499
Gurgaon – 012430304499
Hyderabad – 04030304499
Mumbai – 02230304499
Pune – 02230304499
Kolkata – 03330304499
3. Get online support from HP:Â https://support.hp.com/in-en
If you have a problem with your laptop and it is not starting, make some troubleshooting first to see if you can fix it yourself or to know what might be causing the problem. If the laptop is not starting up or doesn’t turn on, check the battery first. Plug the charger to the power and connect it to your laptop.
If the machine doesn’t turn on, disconnect the charger from your laptop. Next, turn the laptop upside down and remove the battery. After this, connect the charger again back to the laptop then press power to turn it on and see if the machine powers up. If this doesn’t work, try using a different charger and make sure the AC outlet has power.
If nothing works, bring the laptop to the nearest service center for servicing. To see the service center locations in your area, go to HP Customer Support – Service Center Locator.
