How to convert from 64 to 32 bit?
I use windows 7 64 bit version but now I want to convert from 64 bit to 32 bit. How can I do so? Do I have to reinstall the
windows to downgrade it? Any advice would be appreciated.
Hi there ,Â
There are lots of Windows programs that doesn't support 64 bit architecture. So that good to change to 32 bit .Â
Let me remind you that these 2 has very different process stuffs and you need to re-install it. Use the advance properties in windows and backup your files and then re-install it .Â
Hi Frank ,
Hope the following steps will guide you in fixing of this issue.:..:
Thanks Lesten Pasio,
I found out that my drivers are not compatible to 32-bit. But I really want to reformat my laptop. So I followed your instructions and choose 86-bit.
Thank you very much.
