Mia Molly
20 points
Posted on - 10/04/2012
Hi experts,
How to convert acrobat pro PST in PDF?
If there is some software that will allow me to convert those kind of files it would be easier for me to finish all of this on time.
I have so many files to be converted I hope you can help me to get and download a helpful software.
Thank you.
Hi Mia,
You wanted to download software that can convert acrobat pro PST in PDF. There are many such kinds of converter. You can try "FoxPDF PST to PDF Converter 3.0".
This version is good and may not give any headache to you in the process of installation and use. On the web you may find many pages and links that shall lead you to such kind of download, but most of them are affected by viruses and malware contamination and not at all safe for your PC. I tried to find some links for you that are secure.
Try them:
This one, I think, is better:
OR,
Here is another one:
You can use both of them easily.
