How to convert Adobe pdf converter to excel?
I work in a reputed Banking agency. I receive many PDF’s to be converted into Excel and process calculations on those files. But using the converter I am only able to convert into Word file. And the word file needs to be made into excel. Which Adobe converter pdf to excelcan I use to make my work faster?
Answered By 0 points N/A #125004
You can use the Adobe Acrobat Pro to convert from PDF to Word, Excel, and PowerPoint. You may also use the software to directly edit the PDF and save the changes to the PDF files.
This software can also be used by your firm to validate the documents and provide signatures. You may also require to password protect or restrict open of documents by using the certificate. All these features are included in a single software called Adobe Acrobat Pro.
