How to convert and edit PDF file to a document?
Asked By 110 points N/A Posted on -
I'd like to know If I can edit some of my PDF files to a document file to be able to edit it.
I need to do it asap and needs help about it.
Best Answer by andlib
Answered By 0 points N/A #89339
PDF files can be edited only after they’ve been converted to a .doc, .odg, .rtf, etc. file format. There are many programs out there that can help with this, eg.
PDF Import Extension for OpenOffice, PDFill, etc. I’ve always used PDF Import Extension for OpenOffice and it’s never failed to amaze me. It can convert PDF files very efficiently, and also converts images in the file into vector images.
This program is available for all platforms like Windows, Linux, etc.
Answered By 110 points N/A #89340
Well, I've searched the web for those programs. I tried the PDF Import Extension, well it works perfectly and I was able to use the program without further having issues with it.
I'm really glad you're able to help me out with my issue.
Answered By 0 points N/A #89341
Well, Rdhee, although PDF Import Extension is a fantastic free solution for editing a PDF it does have some limitations. It does not currently support PDF forms, table conversions, and decrypting protected files. If you are running Microsoft Windows, many of those limitations can be avoided by also using PDfill.
Good Day!
Answered By 110 points N/A #89342
Okay, so If I would like to have the complete program to do it all, I should use PDFill?
Is it the same as PDF Import Extension, because I find it easier to use PDF Import Extension. But still, I'd like to know more about PDFill.
Answered By 0 points N/A #89343
PDFill is another program used to edit PDF files. First, you need to download and install PDFill. Second, open the PDFill PDF Editor if you wish to edit a PDF file or the PDFill PDF Tools if you want to encrypt, decrypt, merge, add headers, add PDF, or perform other quick tasks to a PDF file. Next, if you are editing a file, after PDFill PDF Editor is open click File, select Open New PDF Project and browse to the PDF file you wish to edit. Isn't that easy?
Also, It may take several minutes to convert a PDF file and online services do not convert password protected files. There are several online tools that can convert your PDF files and because it's easier to edit a PDF as a Word file., without using the software tools we've told you about, I also recommend the PDF to Word converter by Nitro PDF Software. Of course I still recommend you to use PDF Import Extension or PDFill as of the moment.
Answered By 110 points N/A #89344
Thanks for all your help. I'll remember everything you said, you're both great.
Hope you could help me out on my next issue just in case, he he!!
Answered By 0 points N/A #89345
Adobe Acrobat Writer is the best solution to change contents of PDF files.
