How to convert animated gif to swf in Mac OS?
I have Mac OS X and was wondering if there is a way to convert animated gif to swf? If somebody knows any good utility or method to do so, then tell me. Any kind of help would be appreciated.
Hello Alex,
You can use the iOrgsoft SWF to GIF Converter to do that. Once you have downloaded and installed on your computer you will need to do the following:
Hope this helps.
Carl
You have to download a flash cs5 which is a tool for animation makes sure that you will download the flash cs5 that is compatible with your MAC Operating System. And kindly try this website this will help you a lot to download a Flash CS with any version which is available and the package is also available with MAC OS for compatibility reasons https://adobe-flash-professional.en.softonic.com/mac .
Here are some additional tips:
You load the Gif. To your new flash tool and you can convert it. Cut into pieces all the materials using adobe Photoshop so that you can be able to load it to the flash software and you can now put motions in to the pictures. Make sure that when you cut all the materials save as with an extension of “ .png”. When the animation is done it will be save as “ .swf”.
