Greetings Techy members. I hope all is well. I would like to know how to convert avi to rmvb converter ubuntu successfully. What are the needed steps for this? Please include an overview as well as a detailed guide for this kind of conversion. Can you recommend something that is also as efficient yet faster?Â
How to convert avi to rmvb converter ubuntu successfully?
I know anime types like RMVB but it's terrible format , IMO it's propitiatory , so no legal converters exist except those from Real.JMO but i would fine something more universal like Xvid.
Any output from AVI type file to any other will lose quality losses in the encoding process.
With Real you would have to experiment with raising the bitrate until the quality is as good as the AVI file if you want to minimize quality loss.
The operation is mostly by 'feel' as i don't know what you started with.
I would make up short representative file of 5 minutes and try different bitrates with Real till you get one that will give you the best quality vs filesize . The filesize will likely have to be higher than other Real videos as you need to make up for encoding losses
