Dobik Triko
Posted on - 08/17/2016
Hi. I am a student currently in 10th standard. I have been trying hard from a long time to convert audio to mp3 but don’t know the procedure how to go about doing it. Could you let me know how to convert CD audio to mp3? Please reply ASAP. Thanks in advance.
How To Convert CD Audio To Mp3
Hi. To know how to convert CD audio to mp3, first download the audio CD to mp3 converter online for free. To launch it, first click on start, then all programs, click on DVDVideoSoft following which select programs, and click on the icon of the DVDVideoSoft on the desktop of the PC. Then, insert the audio CD into the drive so that the audio tracks are detected. Select the ones which need to be copied. Browse the location where the converted audio files need to be saved. Then click on OK. Then click on the file name and save it with the mp3 format.
Select the quality of the file in which the audio file is to be saved. Finally, when all the settings have been made, click on the convert option to convert the audio CD to the mp3 format and wait for a few minutes while the conversion takes place. Close the window.
Hope we helped.
If you have an audio CD and you want to convert the music into MP3 format (*.mp3), it cannot be done by just copying the CD tracks to your hard drive. Converting the music means ripping the tracks from the disc. One way to do it is to use ImTOO Audio Maker.
It is priced at $39.95 if you wish to buy it but you can also download it for free. I just don’t know the limitations for the free download. It supports Windows XP Service Pack 2, Windows Vista, Windows 7, Windows 8.x, and Windows 10.
It requires 1 GHz or faster Intel or equivalent AMD processor, 256 MB RAM, 30 MB free space, 800 x 600 minimum screen resolution, 16-bit sound card, and CD or DVD writer (optional if you wish to burn discs). Another way is to use Cool Edit Pro. It supports ripping of audio CDs. Download Cool Edit Pro 2.1.
