How To Convert A Cd To Mp3, Add Music To The CD?
I need to convert a CD to audio CD so that it may be impossible to copy the music contained on the CD and also add more music to the CD. So how can I convert a cd to mp3?
To convert a CD to an audio CD you need to write many lines of code so that it will support with any operating system according to user’s will. This may feel to be a cumbersome task to do. So I would suggest buying a CD rip software which will burn the CD and make sure that they cannot be copied to any external sources. To add more songs to the CD, later on, won’t be possible as it would be required to re-burn the CD, which is not possible in the normal CDs.
