How to convert from dbf to oracle file?
I was wondering if there is a way to convert from dbf to oracle file. If someone knows any third party tool, then any kind of help would be appreciated.
Do you want to convert dbf to oracle? Ok, no problem. I'm sharing a link with you below.
https://www.convert-in.com/dbf2ora.htm
Go to the link and buy the converter. If you have any doubt, you can download a demo with limited feature. Download and try yourself by following screen information. It is very easy.
The price of the converter is $39 only.
Thanks for asking.
Hathy
Hello
I've found free solution for your problem. I found application called DBase. It enables you to import your data into Oracle database from .dbf. After importing your data you can simply save your Oracle database and you'll have Oracle database with information imported from .dbf database. Just input location of your dbf database, username, password and TNS, the rest of process is automatic.
Check this link to download this application: http://www.webxpert.ro/andrei/2008/05/30/dbase-dbf-import-to-oracle-freeware-tool/
Notifications
