How to convert DM audio files into mp3 files?
I have lots of DM audio files in my PC. I want to convert them into mp3 files so that I can have them on my mobile phone as well. I need a reliable DM audio converting software.
ThanksÂ
ThanksÂ
 You can convert your DM files to MP3 online, on this link: http://www.zamzar.com/ or http://www.youconvertit.com/ConvertFiles.aspx First select your file, browse from your computer then in convert to find the MP3 format and enter you email address, where will be sent downloading link for converted file. If you have in extension like .aac.dm then you will not be able to convert that file because is copy protected. To fix that rename the file just with .acc extension.
Williamson Mellisa
Hi Ferrari Donald,
It is nice to have a conversion software in your PC so that you can convert the file and use the same in your mobile.You can use this link to download the conversion software. This software is free to use. Once you have downloaded and installed the software follow the below instruction.
Andrew Shakava
