How to convert Download old lotus 123 to MS Excel?
hi, Are there any Microsoft software that can help me to convert my download old lotus 123 worksheets into Microsoft excel 2010 worksheet?If it is not possible what type of Microsoft excel version can be compatible in converting old lotus 123?. If you know how to do this please explain to me step by step on how to do that. Thank you.
Answered By 0 points N/A #197069
Hello
Well, you can open your lotus file with excel itself. But before opening you should unblock it extension, follow these steps:
Go to: File -> Options -> TrustCenter -> TrustCenter Settings
After you open settings dialog then go to File Block Settings -> then enable file extension you need (wk4 in you case)
After you complete those steps open your lotus file and save it in any format you want.
Regards.
