How to convert a dvd into mov on Mac?
Hello everybody,
I just want to know how to convert a DVD into mov on my MacBook so I can play it on my iPod and iPhone.
Thanks in advance.
Hello everybody,
Thanks in advance.
Hello Frank,
The following are the steps for converting a DVD into MOV on a MacBook:
Carl
Dear User,
You can easily convert your DVD to Mov by following these steps,
1. Download this application using this link.
2. Install it on your MacBook.
3. Now open this application and go to file and load DVD.
4. Locate the DVD and add them.
5. Open the format list of the app by going to General Video Formats and set MOV as your format.
6. Now press Convert to get your videos converted.
Thank you.
