Hi guys, I have many DVD's obviously I'm found of music so I want to try playing them in Ipod but got an idea to get some creative and try something new so I want to convert DVD so that I can play that on Ipod.Please tell me is it possible to do so and if yes how to do it is there any free software available using which I can complete this work.
points
How to convert a DVD to play on ipod touch 5?
iPod supports many popular file formats. The supported file formats are MP3, AIFF, WAV, AAC formats. In order to have your DVD files into your iPod, you need any good file converter. Here are some with very good quality.
The best one is Format Factory, in my choice. It supports any media file to be converted into a large number of supported files including iPod ones. It’s easy to use, fast and effective. Download Format Factory.
You can use any other converter, just make sure that the iPod file formats are supported.Â
