How to convert DVD to Samsung Galaxy SIII?
Hi experts, please give me a solution. I want to convert some DVD to my Samsung Galaxy SIII. How will I do that?
Samsung Galaxy S III is a very good media player which supports a lot of media formats like MP4, DivX, XviD, WMV, H.264, and H.263.
Brorsoft's DVD Ripper, will give you the best DVD ripping technology to convert your favorite DVDs into Galaxy S3 supported video format. Brorsoft brings you DVD rippers for both Windows and Mac.
For Windows users: http://www.brorsoft.cn/dvd-ripper/
For Mac users: http://www.brorsoft.cn/dvd-ripper-mac/
Using this DVD ripper from Brorsoft you can experience an amazing DVD video quality on your Samsung Galaxy S III.
Both the software will cost you $28.
uRex DVD Ripper Platinum is professionally designed for converting DVD videos to Samsung Galaxy S III.
You can buy uRex DVD Ripper Platinum here http://www.urexsoft.com/dvd-ripper/index.html
It will cost you $34.95
or you can just download the trial version of uRex DVD Ripper Platinum here www.urexsoft.com/down/setup-urex-dvdripper.exe
If you are a Mac user and you want to convert your DVD’s to your Samsung Galaxy S III then here is another solution for you “Leawo DVD Ripper” http://www.dvdconvertersoft.com/dvd-ripper-for-mac.html . This DVD ripper will cost you $35.
You can also use Aura DVD Ripper to rip your DVD’s to your Samsung Galaxy S III.
You can get Aura DVD Ripper here http://www.aura4you.com/aura-dvd-ripper.php
There are some simple steps for you to follow to convert DVD’s to your Samsung Galaxy S III.
1. Select the DVD file you want to convert.
2. Choose ‘Subtitle’ and ‘Audio’ format.
3. Set the ‘Output’ format.
4. Finally get back to the main window and just click the button “Convert”.
You need a converter to implement your idea. Check the file format that is supported by your Samsung Galaxy SIII and convert files using software. You will be then able to play them on Samsung Galaxy SIII.
Smith Thompson
