How to convert dwg filer acrobat x
Is there any way to convert dwg filer acrobat x to PDF in adobe? If it possible please give me the steps to do it.
Hello Catlin,
There are a lot of software all over the web that convert dwg file to a PDF file. Like:
You can also use AutoCAD to convert DWG to PDF.
If you don't want to download and install those software, there are also site that offer the same functionality.
Hope this helps.
Hi Catlin,
There is a way to convert DWG to Acrobat. First, you must learn the steps and download acrobat converter. If you want to learn the steps you can read article or forum and also you can watch the video. Here are the URLs
https://forums.adobe.com/thread/1502007
You can download the product here to start using acrobat
http://www.verypdf.com/autocad-dwg-dxf-to-pdf/dwg-to-pdf/dwg-to-acrobat.html
Thank You!
