I need to convert dwg files to psd files for my work.
Is there any online converter for this or if there is nothing, what will be the best converter for me to convert dwg files to psd files.
Thank you so much experts.
How to convert dwg files to psd files?
Hi Emsley,
There is no converter for that type with dwg file to psd file. But you can try to transform it.
First is open the existing dwg file and save it as .dfx/dfx file.
By this, you can import the desired AutoCAD file in photoshop.
After importing .dfx file in Photoshop, you are able to save as the existing dfx file into psd file then that's it.
Hope this help.
There is already a converter for dwg to psd converter that are available in the internet.
But there is no online for this kind of converter.
Actually I am using DwgConverter DWG to PSD Converter 3.6.0.0 on my projects and in designing.
If I were you, I will prefer to download rather than online conversions if there, because you are publishing your design already to the internet.
Regards!
