Hi experts,
How to convert email lotus notes to mac? Any other formats for mac operating system will do. I am having some problem on the compatibility issue when using this mac operating system. Can you help me on how to convert email lotus notes to mac. Or any other related fixes will do just give me an idea on how to fix this.
How to convert email lotus notes to Mac?
Hi Christine,
You can convert email lotus notes to mac by using lotus note client software for Mac OS X. It involves a local mail server. The solution involves 20 above steps starting from installation of client.
Here's is a link:Â https://kevin.deldycke.com/2010/09/ultimate-guide-lotus-notes-mail-migration/
In this link by following the steps explained in the method #3 you can convert email lotus notes to mac. Every 20+ steps in the solution includes screenshots and directions to convert email lotus notes to mac.
Hope this helps you.
You don't have to convert to Mac. Lotus Notes has supported MacOS for quite a while. If you're using Mountain Lion, there was a problem with the Mac OS X upgrade overwriting some Lotus Notes files, but that problem has been fixed. See the IBM Tech Note
