How to convert excel to Mac readable file?
I have been using some files which are in xls format but my client having MAC OS and he is unable to view files and I need a tool which help me into convert excel to mac readable files?
No need to use a special tool or software to make excel files readable in Mac. Follow these carefully to be able to view your excel files in Mac without even downloading it.
Click on the "Finder" to show all the files on your computer.
Locate and launch the Excel file you wish to view.
Click once on the Excel file, then press the "space" bar or click on the quick Look icon at the highest of the "Finder" screen. Your excel file can appear in a very new window wherever you'll be able to read the file.
If an excel file is emailed to you within the Macintosh Mail program, you just need to click on the file and it will automatically convert itself to a readable file without even downloading.
