How to convert excel to text
You can download any free convertor that will convert your file Excel to word or text file. And it is free also.
One of this is excel to text 2009 converter. Their download link is given below.
http://www.excel-tool.com/download/convertexceltotxt.exe
First download this and install on your computer. After installation you can run this program and convert any excel file to word or text. You can convert a lot of excel file to word or text.
Second way to change excel to word is that, You can copy your excel text and paste it to your favorite text editor or ms word.
Which version of ms excel are you using? If it ms excel 2007 0r ms excel 2010, then it is possible that you can save the excel file that you want to convert to a text file directly from the excel itself. All you have to do it do the following:
Regards
Thompson Locker
