How To Convert Frame Maker To Word Using Some Simple Steps
Hi. I want to learn how to convert frame maker to Word. It is really urgent. Please reply ASAP. Thanks in advance.
Hi. To learn how to convert frame maker to Word, first open the document by clicking on file and then open. Next, click on the file option again and select the save as option. Give a name to the file and then select the .doc extension for the save as type of the file. After the conversion is over, open MS-Word and then click on file and open to open the frame maker file which has recently been converted to a Word document. To edit the final frame fixes in the Word document, first remove the section breaks.
Next, combine all the tags which you find similar to each other and remove the unwanted tags.
Hope we helped.
