How to convert image files to PDF format?
How to convert photos(image format: . jpeg, .gif, .png) to pdf document and how to re size and combine multiple photos/images in single pdf by using photoshop?
PDF is a certified file format. Any kinds of documents, photos etc.(except videos) can be converted into PDF document. You should use PDF converter software such as DoPDF, NovaPDF etc. Using any of these converters, you can make photos into PDF file.
But if you want to resize, you have to resize the photos before converting because these converters can't resize photos. You can use these software to resize photos: Picture Resize Starter, PhotoRazor, Microsoft Office Picture Manager etc.
First of all, resize the photos as your wish and then use the converters to convert into PDF.
If you want to create a series of photos on eBook, you need to create electronic booklet, or you want to send series of photos via e mail, the best way is convert them into Portable Document Format (PDF), because PDF documents can be viewed and printed on any computer regardless of the printing device or operating system.
You can simply convert photos into PDF documents through MS-Word 2010 or using the Open office – writer software.
PDF file review a complete description of a fixed-layout flat file.
You can convert image to pdf by using many software. Choose a software, Some are freeware like Bullzip PDF Printer, GhostScript, CUPS-PDF, CutePDF Writer, DoPDF, PDFCreator etc and some are commercial such as Adobe Acrobat, NovaPDF. You should add image files in any format and click to Convert, software will convert them to a PDF. You may set page size and some information. Some software also combines multiple images into a single PDF like PDFCreator.
This is the best idea to re size your images before convert. You can use Microsoft Office Picture Manager, Paint, PhotoRazor etc and crop or re size your image as you wish.
Hi AmitSharma,
There is much software for you to convert your images to pdf file. I suggest two of them, because those are easy to use.
– Image to Pdf Converter: This software supports large range of image format: BMP, ICO, GIF, JPEG, JPG, JPE, PNG, TIFF, PCX, RAW, PICT, PSD, … All you need to do is adding your image files to list and then click on Convert button. You can download here: http://www.pdfarea.com/Image-to-PDF-Converter-Free.htm
– novaPdf: This soft supports such format: jpg,jpeg, gif, bmp,png. Click on Print button > in printer, select novaPDF and choose paper size and quality > click on Print button and give your file a name > click OK. You can download here: http://www.novapdf.com/kb/convert-jpg-to-pdf-or-other-image-formats-to-pdf-105.html
Once you have all “image” pdf files, you will combine all of them into a unit pdf. Open Adobe Acrobat Pro program and follow these steps: Open one file first > File > Document > Insert Page… (Shift + Ctrl + D) > choose From File… (Shift + Ctrl + I) and locate the other files
Hope this helps
