Isabellartd
70 points
Posted on - 11/06/2012
I need help on how to convert to ISO format to virtual HD format. I have tons of .ISO files and I need to convert them all to .vhd file so I could load it up on Virtual PC 2007. Can anybody suggest an easy way to do this? Great thanks for whatever help you could share with me.
How to convert to iso format to virtual hd files?
Hey Isabella,
There is not need to convert the original .ISO files to .vhd files for using them with Virtual PC 2007.
You can directly import the .ISO files in Virtual PC 2007.
From the top of the Virtual PC 2007 Window.
> Click on CD.
> Capture ISO Image and select the image (.ISO) files that you want.
Hope this helps you.
Rishen
In virtual PC 2007. There is no need to convert ISO files to vhd files. In virtual PC you can capture the ISO in Cd tab.
