lawrence
Posted on - 03/22/2013
Hi there,
I work in a media company that primarily deals with video distribution. My boss has tasked me to convert around 150 videos in ivr format to avi.
The problem is I can't seem to find any converters that seems to be able to do that.
Can any one of you techies provide me a ivr to avi video converting software?
How to convert ivr to avi
Hi Lawrence,
There is a program just for you. It is called AVS Video Converter. Here is the link to their official site. After downloading simply browse for your .ivr files, select the output method you want, and press convert to start the process.
Best of all, it is completely free.
Good luck!
You can use this website AVS4 You to solve your problem. All you need to do is follow the instruction below:
1. On the website I provided, you need to download the AVS Video Converter which is a free IVR to AVI video converting software.
2. After the download, you need to launch the software on your computer.
3. On the toolbar on top of your screen, you need to select the output file type into "TO AVI" so it is set to AVI file type after converting.
4. Add the IVR file by clicking the "Browse" in the "Input File Name" portion of the screen. You can add multiple files and convert one time.
5. Click on "Convert now" to start the job. You will notice a progress bar and it will be filled until all files are done converting. You will also receive a notification that conversion is completed. Click "OK" to close it and you can start using the AVI files you have converted.
