How to convert JPEG File to .XML?
I’m an encoder an my job is to convert JPEG File or Scan File to .txt file or Microsoft Word and converts again to .xml and send it through internet. Now my question is, do we have a software that can automatically converts scanfile to .txt file? Any Idea?
Answered By 75 points N/A #106410
Hello Ken Jonson,
The method that I know for converting a jpeg file to the .txt format is not by using a software that you will need to install but by using  the ms word editor.
All you have to do is get your image and copy it in a blank ms word document. Adjust the image to fit in the document as you wish, the margins and the size of the image itself, the brightness and contrast. If you need to reduce or cut some sections of the image, then use the crop tool.
After that go to file then save as, choose the other formats options and then in the save as window, choose the .txt format and then click on save.
__
Best Regards,
Lee Hung
