aston aston
20 points
Posted on - 02/08/2013
Hi users,
I am using Linux as my secure Operating System. I have many Linux lotus notes that to be converted into PDF files so that I can maintain the lotus notes in my database. Is there any Linux lotus notes converter software or online tool from where I can convert them into PDF format.
How to convert linux lotus notes into PDF file.
There is software for converting Lotus Notes to PDF such as Kernel. You can download from this website: https://www.nucleustechnologies.com/lotusnotestopdf.html You can try free as demo version that have some limitations. If you like it you can purchase the full version.
Also you can use this SysTools Lotus Notes to PDF: https://www.systoolsgroup.com/lotus-notes-to-pdf.html This software moves the Lotus Notes data to Adobe Acrobat PDF file. With this software you can convert NSF file to PDF completely, view NSF emails in Absence, create and save PDF file in new folder and many more.
Williamson Mellisa
