Hi. I am a student and I am currently in the 10th grade. I want to learn the steps so as to convert my MOD file for my Mac OS X. I need to convert it to MOV for portability but it is not getting converted. Some problem is arising somehow. How to convert MOD to MOV? Please reply ASAP. Thanks.
How To Convert MOD To MOV
Hi. To learn how to convert MOD to MOV on your Mac OS X, first open the software video converter for Mac. Then, click on the add file button to browse the files which need to be converted from .MOD extension to .MOV. Then, click on the export option by clicking on profile menu and then selecting the output file as MOV. After this, you can select the location where the converted file is to be stored by browsing the location and selecting it. In case the file conversion is to be done for some other devices such as iPad etc, then there will be a sidebar from which the device can be selected. In addition to the conversion, the video can be cropped, edited and trimmed. A watermark can be added too if needed. Then finally begin with the MOD to MOV conversion by clicking on the convert option. Wait while the conversion completes.
Look at the progress bar for details. You can also use Movavi Converter by first installing it and then running the program. Next, add the files which are to be converted to the program by clicking on add video option, then browsing the files and finally clicking on open to open them. Then, select the file format by clicking on the arrow in the convert to list and then clicking on video and audio in case the file is to be converted to the a specific format or devices option if the video needs to be played on a mobile.
After this, select the location where the converted file is to be stored by clicking on the browse option. Then, click on convert and wait for the conversion to complete.
Hope we helped.
