How to convert the movie in mms videos 3gp format?
I want to convert my movie into the mms videos 3gp format so that I would able to transfer it easily through mms to share it will my family members. Is their any solution to do this task? I am waiting for an expert opinion.
Answered By 0 points N/A #131198
Hi there friend.
I will make a list of programs which I think are the best, and will help you perform this task.
All of the programs are free to download and easy to work with, and I am quite sure that they will get the job done for you.
1.http://www.moyeamedia.com/3gp-converter
I think this one is the best for you, because it has a lot of input formats, such as WMV, mp3, mp4 and stuff like that.
The output format is 3gp or 3G2, so you can select what you want.
2.http://www.pazera-software.com/products/video-to-3gp-converter/
If not happy with the first one, feel free to try this one, because it`s a 100% free software and easy to use.
A fast fix and a solution to your problem.
3.http://download.cnet.com/Free-Convert-AVI-WMV-MOV-FLV-to-3GP-MP4-Converter/3000-2194_4-10909241.html
Now this is a software that needs a bit more skill to work with, so I suggest you try it in your free time.
I hope this works for you well.
Regards.
