How to convert MP3 to Midi file?
I have tried many times to convert MP3 to midi files. However, the quality of the sound I received was very poor . Everything was unclear. I was advised to use various software programs (E.x. Widi recognition system professional)  to improve quality.  But I don't know how to actually  improve the sound quality using this software. I was only able to convert  mp3 to midi files.
Please tell me if there are any other software packages that could convert MP3 to midi of a satisfactory quality or how to use the  the above mentioned program for the same.
Best Answer by grant price
Answered By 0 points N/A #151028
To convert MP3 files to Midi, please follow these instruction :
1) Download any audio converter which is able to deal with both codec (Goldwave or Total Audio Converter).
2) Select the file by using browse function.
3) Select the output file format, the frequency (48hz) et the bitrate (which is the reference for the quality : higher the bitrate is, higher the quality will be).
4) You can also choose start time and end time.
5) Finally, convert the file.
Answered By 0 points N/A #151029
Dear Eckel andrea
Please follow the following steps.
Dream MP3 to MIDI Converter is an exceptional converter, which can completely change such audio set-up as MP3 and MIDI from one to another. Dream MP3 to MIDI Converter has outstanding exchange, quick speed; convert file size and format, previews and snapshots. Software piracy is robbery, Using Dream MP3 to MIDI Converter illegal version, code word, registration codes, key generators, serial numbers is unlawful
Thanks
Answered By 0 points N/A #151030
You can convert MP3 to MIDI. MIDI is the best file format and helps you to reveal your creative abilities and make it with the least effort from your side. Other formats do not provide good quality while playing back.
The singing or speaking voice quality is not reproduced by the MIDI format while other does so.
MP3 can also be converted to MIDI format. For this you need an MP3 to MIDI converter. It is easily available on the internet and free to download.
The conversion process is very rapid on it, you can quickly convert MP3 files to MIDI.
You can download this converter from www.mp3tomidiconverter.com
