How to convert mp4 to wmv ubuntu?
Hi techyv,
How to convert mp4 to wmv ubuntu? I have some mp4 files that needed to be converted to wmv file extension, do you have some knowledge about converters which is compatible with Ubuntu operating system? Compatibility measurements is very necessary to avoid future problems.
Hoping for your help and kind consideration.
Best Answer by Riley weaver
Answered By 0 points N/A #164573
Yes there is. HandBrake Video Converter is an application which is compatible to Ubuntu. It can convert any video formats into any formats you want to. What’s good about this software is that it copies the quality of the video that you convert unlike other software that makes the converted videos pixelated. You can download it at http://www.noobslab.com/2012/03/install-handbrake-video-converter-on.html
Answered By 10 points N/A #164574
Hi there,
There are few very useful packages are available which can help you to do few bundles of converts in just few minutes. You can use WinFF, Hyper Video converter and ffmpeg. All these three converter packages are well known and very much popular to do its job. But ffmpeg is the best between them. You just have to give one line command to change a file and it will do its work in very short time with quality. Now download the package from internet and install that. Now in terminal write the command.
Ffmpeg –i filename output.wmv
I hope you will get a great result.
Best regards,
Riley Weaver.
