Hello experts,
How to convert the mpeg video in mp3? There are some converter I downloaded before that doesn’t allow me to convert mpeg video in mp3 file that is why I need your help to find the best converter for free over the internet. Give me some idea on where can I find it for I need this to be converted soon. Thank you guys.
Hi Madison,
BlazeVideo is a prevailing and specialized video converter for converting MPEG to MP3 format with speedy and quality production speed and quality production quality.
MPEG to MP3 conversion steps are as follows.
Step 1: Load your MPEG source files by clicking "Add File(s)". Batch alteration is permissible!
Step 2: Click "Profile" drop-down list to choose "Common Audio-MP3" as the production set-up.
Step 3: Click "Output-Browse" to choose a folder for saving converted files.
Step 4: Click "Setting" to reorganize audio model rate and audio bit rates.
Step 5: Click "Start" to change MPEG to MP3.
Hello Madison,
You need to download software "Any Video Converter" first; it's free then import the mpeg file from computer and select the output to be MP3. Click on Convert Now button. It's all done.
Thanks
labist
It is very easy. first of all you have to download any video converter software. After installing open it.
1. On the left top you will see "Add video files" just click it and open the required file you need to convert.
2. After opening you will see that file appears in anyvideo converter window and the file is already selected.
3. Now select the output type to mp3 from all profiles button as shown in the following screenshots.
4. Now click "convert now" button and your output is ready.
Hope this will solve your problem.
MPEG is a standard used widely for audio and video formats while MP3 is an encode format for digital audio only.
There are many converter software out there to convert MPEG to MP3, eg.
To convert your file, download and install Xilisoft Video Converter, click the add button and select your MPEG file.
Now click profile at the bottom and select MP3 from General Audio Format.
Click the convert button to start the conversion.
Follow the instructions:
Download and install a video conversion program. Agree to the terms of use and launch the software.
In the software's interface, click the "Add File" button and direct the program to the MP4 you want converted. Open the video.
Select the "Extract Audio From Video" button once your video is loaded, and choose MP3 from the output format options. It is best to stick with the program's default bitrates and channeling options for general conversions
Choose your file's output location (where your computer will save the file to) and click "Convert" or "Start" to begin the conversion. Depending on the size of your MPEG-4, allow several minutes for extraction to complete.
Related Converters : Any Video Converter,4Free Video Converter,Green Free Video Converter,iVideo Converter & Downloader
THANK YOU.
