Good day to all. I would like to know how to convert onenote to html mac osx version. How can I make this possible? What are the steps needed to be taken? Is there a shortcut for this conversion? If not, please kindly give me a step by step process for this.
How to convert onenote to html Mac version?
A good way to go about the conversion of the OneNote file to html will be by opening up MHT in Internet Explorer and then doing the following:
Click File and then Save As "Web Page, Complete (*.htm, *.html) format in Internet Explorer.
Note that you will need to do the above once for every section you want to convert to make the result an html file per section.
Fletcher Hoss
Hi Jimmy M StahI
A third party will make things easy for you. The OneNote Web Exporter application will enable you to export a OneNote notebook as HTML files that anyone can view through a web browser. For instance you give it a OneNote 2007 Notebook and it will generate an HTML page and a folder containing all of the notebook data.
Go through the user guide on the link http://onwebber.codeplex.com
