How to convert or use Mac DV to Webcam
How to convert or use Mac DV to Webcam. I am using OS X and my DV cam is Panasonic MX3000, Please suggest
Yes. Just turn it on and it will act like a FireWire webcam which can be used in any app that recognizes FireWire cameras, such as iChat. Make sure you take out any DV tape inside the camera or it will turn off automatically.
Yes. Just turn it on and it will act like a FireWire webcam. Usually it's supported on OS X without any drivers or software.
Here I will give you information on how many cams work without drivers. Consult the chart below to find out what drivers are required.
Elura 100
Firewire: No driver required.
USB: PTP (No driver required)
GL2
USB: No driver required, supported with ImageBrowser 5.5.
HV10
Still Images (miniSD Memory Card): No driver required.
Firewire: No driver required.*
* Additional third-party software required to import HD video.
XH A1
XH G1
XL H1
XL2
ZR500
ZR600
ZR700
DVD Camcorders
DC100
Direct connection not supported.
DC22
Still Images (DVD/Memory Card): No driver required.
Video: Not supported
DC40
