How to convert an osx cue image? While using my new mac osx operating system I don’t know what requirements needed to download some software from the internet and what am I going to do for the system to allow a specific download. Give me some tips to follow.
Thank you.
Hello Young Hernandez,
Hope that my message finds you well.
First you should open xACT and then navigate to (shntool) tab after that drag and drop any file (.ape) into the box or click add button. Choose (split) and (aiff) bullets.
After that click (Call Shntool) button then when finished select the .cue file.
Some / most app on Mac OS must or should manually be placed in their correct folder to be correctly installed and considered as installed.
Follow these steps while installing:
–      Start your PC.
–      Open Internet and download the application/app …etc on your desktop.
–      Select (Finder) app.
–      Under (Places) header on the LHS of window click (Applications).
–      Drag/Drop the downloaded file into (Applications) folder.
–      The program is now installed.
–      Click on it using system dock and you can use it.
Hope this solution will help you.
Kind regards,
I think i have the solution for you.
Step 1. Open Internet explorer -> Google -> search and download Toast Titanium.
Step 2. Install the program.
Step 3. Click on the item you desire to convert and open it with Toast.
Step 4. Then press File – > Save as disk image.
Step 5. Rename the original file to .iso or other format you need.
Hope this fixed your problem,
Regards John.
