How to convert owl files to SQL?
Hi all,
How to convert owl files to SQL? There are 2 owl files that need to be converted to SQL, I don’t have any single idea on how to get this done properly. Can you give some suggestion on what is the best software for this kind of tasks?
Thanks and have a nice day.
Best Answer by Pludums Srotoshshini
Answered By 5 points N/A #178784
I understand you are looking for a way to convert your owl files to SQL. Below is what you will do:
You will have to first of all parse your owl files with Jena or Sesame. Learn about Jena: http://jena.apache.org/. Learn about Sesame: http://www.openrdf.org/. Having done that, you will get the corresponding triples results in a model or in a graph. At this point you can now do whatever you want to do with the results, converting your owl files to whatever you want.
I hope I have helped you.
Answered By 0 points N/A #178786
If you want to convert owl file to SQL, there is no single way to that and it is not an easy task. You have to do all things manually.
At first you need to manually take the owl file to Jane, get the graph. After that you can convert it according to your choice. For that just rename the format name.
I think you understand.
Answered By 0 points N/A #178785
You wanted to convert OWL files to SQL format. That this is not easy task to do. There is not a single software that can be used to do that. You'll have to do everything manually. First take the OWL files to join and get the graph. After that you can convert it as per your choice in it. Just rename the format to SQL.
Hope that helped you.
