How to convert PDF file to MS Word
Hi experts,
Hi experts,
Hi Mr. Darry,
Hello Darry,
There are couple of good ways to convert PDF file into Microsoft Word file. Here are some suggestions for you to try.
Method 1:
Convert your PDF file online. This is recommended because it does not involve downloading any software to computer, sometimes software we download contains virus and infects our computer.
Keep yourself on a safe side and try this one out.
Here is the procedure to do this:
1. Go to http://www.pdfonline.com/pdf-to-word-converter/
2. Click on Choose file to upload your PDF document
3. Click on Convert button.
4. Save your converted Microsoft Word file safely to your computer.
Method 2:
You can also download a software which converts PDF files into MS Word files. Here are some suggestions for you to try out.
1. PDF to Word Doc: Converts the file within few seconds, here is a link to download:Â
http://download.cnet.com/Free-PDF-to-Word-Converter/3000-18497_4-10849566.html
2. PDF to Word converter: Converts your file and lets you edit the converted document, download it from here:Â https://pdf-to-word-free.en.softonic.com/
I hope this will help you.
Thanks
