AsifYousaf
20 points
Posted on - 09/26/2011
Hi!
Currently I'm preparing documents for my office purposes and all these documents are saved in PDF format. Besides these documents I have many other documents which are in PDF format. How can I convert these documents into MS Word format?
How to convert PDF file into MS Word file?
You want to convert PDF file to MS Word format. That is so simple. Search on Google and download the free and open source software which could convert PDF file to MS Word.
The advantage of open source software is that you will not have to purchase this software. These software are available free of cost. You can download the trial version of Microsoft but that will be only valid up to 15 to 30 days and by converting file on that software they will add a sign due to which this could be identified that you have used the trial version.
So for the best result I will recommend you to download the free and open source software and convert your files using this software. For example you can download open Office of Linux team which is free and available and having more capabilities than MS Office.
Hope this will solve your problem.
Thanks
linda978
Mr. AsifYousaf,
You raised the question which will help many of PDF and MS Office users and I would be more than happy to help you in this context. As if PDF is in simple text anyone can just simply copy and paste the contents but in case of diagrams, headings and bullets this option fails.
There are many downloadable PDF to Word converters available which can help you out on trial basis try one and other after every expiry but be careful about viruses in such case.
Another simpler option is send it to yourself as mail (use some popular mail service) open as html and copy paste the contents as they are.
Have a nice day.
There are websites that offers free PDF to Word file conversion and there are also some tools that you can download.
An example is the PDF to Word.
You can convert online or you can download the trial version on your desktop.
Go here to download PDF to Word. It's just a simple few clicks conversion tool.
Another tool that you can use for conversion is the Zamzar online conversion tool.
They offer 4 easy steps to convert your PDF files.
