Please teach me how to convert PDF file to Word doc. Please tell me which software would convert any text format and photos into text with best accuracy so I can save time editing.
How to convert PDF file to Word doc?
You can convert PDF to MS Word using Nitro pdf convertor. It converts efficiently retaining graphics and text formatting. Nitro Pro 8 is also available, which can create professional-quality PDF documents from any format like paper scans, presentations and more. Another software available for this purpose is convert pdf to word software 1.4. It can also convert pdf files to word easily and quickly.
(OR) You can convert it online as well, from websites like Zamzar and pdfonline.
Laz Zebbena
Hi there!
You can try using Acrobat XI Pro or Acrobat XI Standard software to convert PDF files. Click on this to download a free trial.
Converting a PDF file to Word:
1. Open a PDF file in Acrobat XI.
2. Go to Tools, select Content Editing, and then choose Export File to Microsoft Word Document
3. Click on Settings and turn on optical character recognition if the PDF file you are trying to convert contains scanned text.
4. Create a name for the Word file then save it.
Click on this hyperlink to watch the video about this software: Adobe
One of the easiest ways of converting PDF files into word document is by simply having Adobe Acrobat VI installed onto your system where you can copy all or in most cases part of the PDF file directly into word. If you cannot be in a position of installing the Adobe Acrobat program you can as well visit the internet and here you will find a variety of sites that are readily available to convert your PDF file free of charge.
