How to Convert PDF into Word?
Hi Ramananth,
Kindly go to Google and search for software by the name ‘easy pdf converter’.
Follow this link to download easy pdf converter that will help you to convert easily your pdf document to a word document.
http://www.softpedia.com/get/Office-tools/PDF/Easy-PDF-Text-Converter.shtml
Easy Pdf to text converter works at satisfactory speeds while preserving the original page layout. Further, this software uses a very small amount of resources and CPU.
Optionally you can download from this link where however you will be required to purchase the software.
on this page you will find some instructions and trial software too.
Well, I hope this solves your problem 🙂
Well converting pdf into word is so easy now because of so many different online tools/software to use. You can use nitro pdf software which can help you in any converting works that you're going to do. In this case, you can try it freely online or even in your own desktop. You can also try to use convert pdf to word software which will easily help you do the job quickly. Try using there 14-day trial and check out this website http://www.convertpdftoword.net/ . Another way of converting pdf to word is by using Simpo PDF to Word 3.0. Visit this website http://www.simpopdf.com/guide/how-to-convert-pdf-into-word-doc.html and follow all the steps you need to be able to use this kind of software..
