How to convert PDFs without using swf2pdf command line?
Is there a direct way to convert PDFs without using swf2pdf command line? I am not able to get a hang of how to use the command line to convert.
You can try online converters if you don't want to use the command line to do it. Visit the link below to try converting SWF to PDf files online. It is a free tool and very easy to use. You just have to select a file, wait for the conversion to finish and then download the converted file.
If you want to try another program for converting, click the link below. It is a software that is free of charge.
http://www.swftools.org/faq.html
Hope this helps. Good luck!
Hi dear Jai Zadok
Converting PDF is a simple task. No need to worry about. It does not require any third party software to do so.
You can do it easily by using online website.
Using online is less time consuming rather than using third party software.
You the following site to convert PDF.
Go to the stated link and click PDF convert.
Then you will find many options which may help you to convert
SWF is a file extension used for Shockwave Flash file format created by former Macromedia and now owned by Adobe and it stands for Small Web Format. It can contain video and vector-based animations as well as sound. It is designed for effective delivery over the internet. You can view SWF files on a web browser using a Flash plug-in or the now called Adobe Flash Player.
If you want to convert a PDF file into Flash, you can use a program called A-PDF To Flash. It is a converter that will allow you to convert Adobe PDF into an easy-to-use online Flash flipbook as well as professional Flash content authoring such as conferences, trade shows, e-cards, fun content, e-learning, researching, studies, and many more.
The PDF to SWF converter is very handy especially when you need to embed PDF files in web pages for online viewing or maybe you want to read PDF files on a computer that doesn’t have Adobe Acrobat Reader. You can import multimedia files such as background music, sound, voice recording, and others. A-PDF To Flash supports Windows 2000, Windows XP, Windows Vista, and Windows 7.
It costs around $99 a license and is offered with 30-day 100% money back guarantee. You can check on the video below. By the way, A-PDF To Flash is a standalone program which doesn’t require any installation.
[video:http://youtu.be/O0TAtCq3ceI]
