How to convert personal reasoning into a multiple cloud
How do convert a personal reasoning into a multiple cloud? And what will I need to do to my programs to get them to run in reasoning, personal or public?
First you need to assess the type of personal reasoning you have. Make a list of all those which you think are reasonable and are worthy to be mentioned.
After that, see what you need, make a list of all the requirements and things that are needed for you to work on stuff.
Now search on Google about various cloud computing servers and companies. Most of them give a free space of up to 10GB. If your data is not that much then you can just create a simple cloud without even paying something but if you are dealing with huge number of data, you might want to buy a package plan.
Notifications
